Tanis8472
So we dedicate all farmland to rapeseed production and still not have enough to supply demand?
			Haven't read through the whole thread, so apologies if anyone has mentioned it already, but felling, and not replacing, MILLIONS of trees EVERY year, doesn't help much either.
Especially if the chainsaw uses Diesel!
But, if we're not going to use diesel for cars, boats, trains or domestic heating oil, what should we do with it?
It's a fundamental part of crude oil.
As long as we're making petrol, we'll be making diesel as well. That's how fractional distillation works.
Need?
Those with oil central heating systems in urban homes will be penalised when I'm in charge in order to encourage provision of district heating systems.Also oil fired central heating systems run off the same polluting fuel.
9 said:Well, we're often told that the national grid is running at 98 or 99% of capacity, so if there is a big switch to electric cars, that will almost certainly result in demand exceeding the available reserves - so the extra juice will need to come from somewhere and it will need to be instantly available.
As things stand, the contingency is lots of diesel powered generators.
@swansonj, is this correct?
Another issue is that the grid and transmission is incredibly lossy. I read that somewhere between 25 and 50% of generated lecky is lost in transmission. Listening to my local Ht network crackling on a moist day I can believe it.
For those who like a bit of geekyness
You can see currently demand and generating outputs here.
http://www.gridwatch.templar.co.uk
Nothing like. Energy loss in the grid itself is about 2.3%, made up mostly of resistive heating in the cables and corona discharge when it's wet - that's the crackly noise you hear. There's more loss in the lower voltage bits that run to houses, but even so, it's around 7.7% lossy in total.
https://en.wikipedia.org/wiki/National_Grid_(Great_Britain)#Losses
EDIT - too slow
