confusedcyclist
I recently fitted BB7 MTB brakes to my new commuter. I wasn't heavy handed with the installation or anything, there's 2-3mm of lateral wobble toward the outer disc pads (on both sets) out of the box.
Is it unreasonable to expect the rotors to be true out of the box? I ask because I just can't seem to get them adjusted just right. I'm faced with either noisy brakes as the rotors strike the pads every rotation, or a larger amount of travel due to extra clearance required for quiet operation. The extra clearance means the brakes only bite 100% when the lever is touching the bars, I want a bit more tension than that, but it results in squeal.
I've been thinking about whipping the rotors off the wheels for a bit of DIY truing, or just replacing them, just curious if others have had similar problems with new rotors.
