Accy cyclist
- The hills of Accrington
I was more thinking you shouldn't obsessively sniff your own (or anyone else's) pad
Time for a reappearance i think.
why?I wear mine in bed - the girlfriend loves it!
why?
The extra padding makes the old todger look and feel more substantial of course
If they have a red or orange pad be sure to wear them inside out and run round the house and garden doing baboon impressions.My first pair of padded undershorts are due to arrive today.
I'll give them a test run around the house later and report back my findings.
No, it only misshapes it and puts pressure on the wrong bits of your bum because it's designed for sitting on a hard saddle. It's similar to sitting on a deep gel saddle in padded shorts - the pressure's spread a bit more but it's increased in all the wrong places.The thing is does sitting down on a flat chair kind of squash the padding more than on a bike saddle?
Have you perfected dismount-and-remove-shorts as a single action then?I only wear mine on the bike , but each to their own !
So you'd set out to ride to the pub in wet, dirty cycling shorts? and where do you keep them between the last ride and going to the pub?If you're heading out to the pub or settling in at home for the full evening in dry, fresh cycling shorts however, I'd respectfully suggest you're heading towards the "Saville" end of the eccentricity scale.
But more so, as there's far more material for it to fester in.Same as any underwear...
'InstaShorts! The shorts that take themselves off. A boon for the elderly! And those with tiny tanks!'Have you perfected dismount-and-remove-shorts as a single action then? .
The mechanical structure of the padding is designed to withstand a twisting for of 69 lb/ft and slightly for on sideways waft, now the displacement required when sitting on say a flat chair is only 37.5 lb/ft This means that over a sustained period of maybe 92 minutes some thinning of the cycosymatic piddle storing padding may occur. In laboratory tests it has been found that the padding will return to its natural state of paddiness if washed at 37.2 degrees.
The numbers are different for softer furnishings such as pub seats, unfortunately on this occasion rather than the padding flattening the waistband has been found to tighten.
