gb155
Fan Boy No More.
- Manchester-Ish
If you had to buy one , today, what one wold it be and why ?
Thanks
Thanks
The ContourHD. It's been replaced by the ROAM and prices are dropping.
It has a better image sensor than the drift.
The drift is a good camera though, has a wide angle lens (170 degrees i think) and is fully waterproof.
Read my guide to buying a helmet camera for some useful tips.
I normally look at amazon for a base price, you may be able to get it cheaper
ContourHD - £149.95
ContourROAM - £185
It's probably worth spending the extra on the ROAM, it has the new contour image sensor, rotates 270 degrees, has the 170 degree lens angle (if not in 1080p mode) and most importantly it self meters, so no need to change settings between night and day.
The ROAM is waterproof to 1m. Which basically means It will brave anything you throw at it cycling (unless you throw a canal at it).Contour all the way I feel but it's not fully waterproof ? For sure ?
My ContourHD 1080p's appear to be very waterproof, so much so I never use the waterproof case I have, I am not sure it is the same for all 1080p's.Contour all the way I feel but it's not fully waterproof ? For sure ?
My Contour Plus is not as waterproof, I have found that the only place for water ingress is the join between the rotating lens housing and the camera. I rectified this by using some clear waterproof tape I had bought from Wickes. I have commuted in two torrential downpours just this week and no sign of water ingress.
The HD and + version are water resistant, in a few cases there has been water ingress with very heavy downpours, but this has not yet affected the electronics of the device.
You can buy a waterproof case for the contour cameras.
Although not important to me personally, some Contour Roam owners have been very upset the Roam does not have a 720p 60fps setting, unlike all the other Contour cameras.ok ok, the Roam is it
