Experiments with Rapid Rise derailleur
Ajax Bay
East Devon
the intuitive logic of these RR derailleurs is quite helpful. On flat bar bikes you push the shifters if you need to go to a higher gear and pull/release to go to a lower gear.
On the right hand side of a flat bar bike with typical derailleur, as you say @Mike Ayling: "Release gets you a higher gear, push for a lower gear."
However on both sides of a flat bar bike with rapid rise RD, release gets you a lower gear, push for a higher gear.
@Mike Ayling - do you like your rapid rise shifters (see thread title)? Do yours work a different way?
All uphill
All uphill
Still rolling along
Somerset
Rivendell have now put their OM1(Opposite Movement) derailleur on sale in the US. It's likely to be sold here with Dia Compe branding.
I'm saving my pennies to buy one along with matching Dia Compe bar end shifters.
Anyone else agree that this arrangement gives a very practical and simple gear change?
raleighnut
No, quite the opposite in my experience. The only advantage I can see is if a cable breaks it defaults to the largest sprocket not the smallest thus leaving you in a usable gear.
Punkawallah
Or you use a cable tie to hold your derailleur in the required position?
ColinJ
Puzzle game procrastinator!
Or move the mech in by hand, and adjust the endstop to hold it there.
It is what I have done on the old bike that I use on my turbo trainer, which uses virtual gearing. The gear shifter on that bike was broken and not needed anyway, so I have moved the mech to exactly line the jockey wheels up with the Zwift cog and fixed it there.
Ive just been given an old Ridgeback with a RR derailleur. Will probably strip the bike for parts. It'll be interesting to see if the mech is worth anything when i come to sell it. Are there enough Riv fans out there to create a demand?
raleighnut
Some of those old Ridgeback frames are really good, mine is a Tange CrMo frame................lovely bike in fact close to being one of the favourites.
The theory behind them is quite good. Push the levers for a lower gear, pull for higher.
Not sure about the mechanical issues though.
All uphill
All uphill
Still rolling along
Somerset
There is definitely a market for them., particularly the XTR ones.
All uphill
All uphill
Still rolling along
Somerset
I've had one on my Temple with bar end shifters and like the symmetry - up to change to a higher gear for both front and rear derailleur.
I've had no mechanical issues.
