Rob3rt
Man or Moose!
- Manchester
I think he means that people who buy carbon sell it on within a season to buy the next. Not that it breaks within a season.
Yes Christopher – it's already got a generous factory-fit clear protective tape over the chainstay (probably helicopter tape or something very similar)Has the OP though to protect the chainstay from chainslap with something like a neoprene sleeve? That is assuming the bike didn't come with such a thing. I've had bad paint chips from this, something you don't want on carbon.
Very interesting thread. I must admit I've never considered putting anything like helicopter tape on my bike frame before!
Stupid question I'm sure - but what's the point?
Stupid question I'm sure - but what's the point? Is it for re-sell purposes (to preserve the bike), to preserve the aesthetics for personal satisfication, or to prevent some form of technical failure with the bike? If the latter, does it really matter though if the manufacturer provides a life-time warranty on the frame anyway?
I ask just because I'm due to get my first road bike through the C2W scheme and although it's not going to be a lot of money in road bike terms (£1000) it's going to be the most expensive bike I've ever purchased (eeek!) and I'm going to be using it for my commute. Should I be considering this, or more hassle than it's worth?
Read it then! It will give you the answer to your questions! Hint: Have a look at the picture GrasB's posted!
How much hassle can sticking a strip of tape down actually be?
As Rob3rt has pointed out above, it's all in the previous few pagesVery interesting thread. I must admit I've never considered putting anything like helicopter tape on my bike frame before!
Ah, ok fair enough - so basically to prevent cable rub and preserve aesthetics.
Yes, I guess putting the odd bit of helicopter tape down in strategic places wouldn't be much hassle - but I personally wouldn't want to wrap the entire frame!
Will this cause technical failure? I doubt it.
Essentially yes... we cross postedAh, ok fair enough - so basically to prevent cable rub and preserve aesthetics.
I'm not planning on wrapping the entire frame, just the important bits as mentioned before – e.g. where cables rub, and under the bottom tube (prone to stone chips). Most bikes will come with some form of chainstay protector, and my Trek already has clear tape on itYes, I guess putting the odd bit of helicopter tape down in strategic places wouldn't be much hassle - but I personally wouldn't want to wrap the entire frame!
Good point – glad I'm sensibly planning on preventing the wear in the first place thenI wouldn't count on that, given the likely shape of the wear pattern it could induce a stress point from which a crack may propagate, this is a problem for both carbon and aluminium. More exclusively with carbon it would cause it to begin to fray and moisture etc can get inside and eventually cause de-lamination and failure.
Agreed... it's going to get scuffs here and there, but I hope to goodness I don't go and crash itI couldn't give two hoots about a little bit of a scuff here and there, some marking is inevitable on a bike that is well used. not saying I wouldn't be upset by large crash induced scrapes etc though.
I do the down tube and rear of the seat tube on mtbs, as I never use mudguards on them. My old Cube frame has a lot of rub marks on the both chain and seat stays.
