Hi!
I have a hybrid with a triple 48-38-28 crankset, 8 speed . This bicycle was working perfectly well and also well maintained. Suddenly the shifting of the front derailleur has gone bad. That is, it does not shift smoothly from the middle chain ring to the largest, there is a lot of noise and then it shifts with a lot of effort. If i increase the cable tension which makes the lever super hard, the drop to the middlechainring becomes an issue.
If I try it on a work stand it is super smooth. All the shifts are perfect .
Please let me know what is the solution, I have worked on bicycles , and can manage some what , but I am at my wits end here.
I had changed the crankset from 42-32-22 to this one, and the shifting was perfect for quite some time, until this happened.
Any help would be appreciated.
