On the matter of front lights, a point that intruges me is the number of cyclists who only have a rear lamp fitted when cycling at night. Yes, motorists can see you from behind, even though they have headlights. But my take is that a good front lamp is more important because when coming up to junctions / side roads / roundabouts etc., then motorists can see you approaching from such angles that their own lights can't pick you out.
It was just within living memory when the government of the day made rear lamps on cycles compulsory and no less that the CTC railed against it arguing that the onus was then put on the cyclist to be seen rather than the motorist to see the cyclist. Front lamps were of course virtually universal in those days of less reliable street lighting.
So what's your take on this - ?
my take simongt is drivers should drive carefully and even if there was a stationery object on the road (like a parked motorcycle) they should not drive into it , having said that as a cyclist i have to make myself as easy to be seen as possible in poor lighting conditions due to the number of careless drivers about, a good set of lights may seem expensive but in my view well worth the cost.
when i see a cyclist out in the dark with a cheap/poor set of lights i really hope they are ok, i have had so many scares on a bike at night i would not cycle in the dark without 2 sets of reasonable lights now.
there was a cyclist killed on a well light road a few weeks ago very close to where i live at 5.50am, the lezyne light may not be the best of the best but they are very bright and i know if i have 2 rear on, one flashing and one steady they are not easy to miss i have even been told by friends that they are to bright, brighter than car fog lights and i notice that the brighter the rear lights the further away drivers seem to stay, only my view/take.
also check out the light output of some rear lights some are 5 lumens and others up to 100 me i would like some bright ones for the dark low out put may be ok for day time but thats another talking point, safe cycling, ttfn.
