Isn't GT85 a water repellent? So it should keep water off the chain so can only be good yes?
Its all I have been using on the chain for several years now, I can't see a down side, I get decent mileage from my chains.
I have been using GT85 spray on my bike chain for about the past 6 months and it seems to be doing a good job . Do you or have you used GT85 spray if you have what is your feedback on it
Don't apply too much chainsaw oil though, it gets flung off the chain and sticks to everything else!Acting on advice elsewhere on the forum, I decided to give chainsaw oil a try. At only £5 for 500 mL at the local hardware shop, it is a lot cheaper than the bike oil from the LBS.
So far, so good. I used the 'Mickle method' to clean and lube a chain with it. I've only done 16 miles on the bike since, but so far, everything seems to be running smoothly. I do wonder if I am going to get more grit stuck to the chain now though - I was using dry lube before.
Me and my m8 bought same bikes together , mine was full Ultegra and his was Dura-ace , I used 3 in 1 high professional lubricant and he used GT85 , his chain and cassette were done at 1500 miles ,still got my cassette with 8000 miles on the clock .
Also - the chainsaw oil does seem pretty thick so I think it would be a grit magnet if not kept under control. I let it soak in to the rollers of the chain and then wiped off as much as I could from the surface.Don't apply too much chainsaw oil though, it gets flung off the chain and sticks to everything else!
Dry lube?? in Hebden Bridge?? hahaha!
