glenn forger
A cyclist ducking and diving may be slightly irritating, an HGV driver doing the same is homicidal. So, not the same. Not remotely the same. Not even in the same ballpark.
If this is you sharing your mistakes why was I made to think by the heading that this this was the lorry drivers mistake not yours. It souds like a bit of a few steps back on your behalf.
There is no point in having an enquiry into why HGVs dont indicate, after the fact. If you continue to ride like that round trucks you will not be here long to talk about it.
Personally, I would have backed off and let him get out of the way, regardless of whos right of way or piece of road it was. How long in your life would it have taken? 3 seconds maybe.
I have to keep going back to watch the clip before I reply but having done so (again) I can without doubt say that your attempt to pass the skip lorry at that point is not even remotely close to 'filtering'.Because ....... then perhaps I wouldn't have thought it safe to filter.
No he's not.Well in light of this impartial analysis it is now obvious that the driver is completely faultless.
No he's not.
Is the driver's actions of manoeuvring his large tipper truck before (or as) he indicated across a taxi stand to the other side of the road and back again so predictable?
Not by a long shot. His actions are questionable but it is your aggressive attempts to get ahead at any cost that got you into that situation. You then repeated the error straight away by forcing your way past the bus which your clip clearly shows is visible squeezing through a gap on your left and continuing his journey, but you decide to attempt a pass anyway and force your way in front of him too.Well in light of this impartial analysis it is now obvious that the driver is completely faultless.
Basically this vid doesn't reflect well on either cyclists or skip drivers. Bit of an own goal IMHO.
