OK guys, you don't like being told things you don't like even though they might be very extreme hypothetical ideas.
The problem is from what I can gather class 2/3 short bodied tipper/construction vehicles.
Other than the area directly behind the vehicle. Plus in line with the door/windscreen pillars.
THERE ARE NO BLIND SPOTS ON THAT TYPE OF VEHICLE lets get that straight. The cab has a minimum of three mirrors
on the near side one looking down over the top of the front wheel, the other two looking down the side of the vehicle, a long one
to give full view down the side and to the rear, the smaller one is a wide angle one which is intended to do just what it says. These
three mirrors do just that give the driver a good view down the nearside, remember this is not on a vehicle that is articulated in any
way.
Adding more mirrors cameras won't improve anything if the driver doesn't use them, ( calm down guys and stop cheering) At present
the large % of this type of vehicle is open sided, eg you can see all the chassis. If it is filled in by rails as you find on Class1 vehicles
to prevent someone falling under them, all that will happen is the victim will end up on the floor and roll under the gap that there has
to be, to allow the vehicle ground clearance. Before someone says make them into a skirt that will just push the victim along the floor.
You will also find the odd "cyclists" up the inside leaning on the rails, please don't say it won't happen.
Is there a solution, yes but only through education, I know @classic33 doesn't believe in simulators but you can't put a person there in real
life on the test as someone would get killed. From an articular I read yesterday it seems that this type of accident in London killed 5 women.
Now before anyone says anything lets make this clear, if someone is nervous in heavy traffic, then that is NOT the place for them. They are
male/female an accident waiting to happen. Some people don't like driving there car on a motorway and therefore don't, some don't like
driving at night and likewise don't. Surely if a situation makes you feel bad don't do. That is not picking on anyone nor is it trying to deflect anything
just stating the obvious.
HGV's don't kill cyclists, just the same as guns don't kill people, bad drivers kill cyclists.
Not at all, what you proposed initially regarding test for bikes, licensing etc does not tackle the issue of cyclists dying in London, and as such was (quite rightly) challenged because what you was saying was not right.
However reading the above we seem to be making some headway regarding what the actual problem is. I agree that if someone is nervous that being in a large amount of traffic is not for them, however this should still not make any difference regarding a HGV driver accounting for them in the way that they drive.
I'm sure with your experience (over 1m miles) you have come across all sorts of drivers and riders, you simply adapt the way you drive and in doing so account for what the other person may or may not do. It is what you are paid to do and is what is taught to you when you learn to drive a HGV.
