Skibird
- Brighstone, Newport
Lol, that's a bit difficult when you now live in the Isle Of Wight where even the roads you think are flat have inclines.
Yep that’s how I do it!Definitely a plodder here as well, and if that fails, then walk.![]()
+1 to all of this.Short sharp hills - keep in the gear I'm in and stand up if needed.
Long draggy hills - get in what I anticipate is the correct gear at the bottom and grind up seated.
Standing uses more energy overall because you have to support your weight as well, but it's better for sudden bursts of power because you can use some of your mass to put more force on the pedals (but you are supporting all of your mass, so overall it's less efficient)
Doing whatever suits you is best though. When I first got back on a bike a few years ago, hills on my commute I now barely notice were stand-up thrashing away with all my effort hills. You will get there is you stick with it!
Another tip - make sure anyone who might be sitting on your wheel is aware you are about to stand up and climb. Several times I've sitting on wheels up climbs, the rider in front stands up and the sudden reduction in speed means that I've nearly gone into the back of them.Mostly seated. Short, steep hills I might get out of the saddle. Tip - change up a gear before getting out of the saddle.
Short and steep, stand up. Long and gradual, sit down.Hi All,
I'm trying to improve my confidence and ability up hills but really struggle to stay seated on any hills, which I'm working on. What works best for you and why (fitness, ability, preference)?
Thanks
Bev
That standing can be useful in urban situations, to get a commanding view of the lay of the land. I find it hard to know when someone else is in a wrong gear. They could always be doing cadence work, or other training (I suspect not most of the time though).Sometimes around London, mostly flat of course, I quite often see folk out of the seat for longish periods for no great point. Usually they are just in the wrong gear.
