Anonymous1502
For road bikes. The recommended pressure for my bike tires is 110PSI how often do I need to pump them?
I've done that, not quite 100yds, but every mile or so when I've had a slow puncture and I've already used my last tub.Every 100 yards.
Are you sure it doesn't say max 110psi on the side wall?For road bikes. The recommended pressure for my bike tires is 110PSI how often do I need to pump them?
But you do run solid tyres.On every full moon.
^^^WSS^^^It'll depend on the brand of the tyre too. My Marathon Plus hold their pressure really well. I don't need to check & pump them up often.
I'd suggest you start off by checking regularly and you'll get to know what they're like and how quickly they need topping up.
I had a look at my wheels again it says 110-125psi on them.I weight 52kg the tire width is 25x700mmWhen they need it. I might give mine a check and a squeeze once a week or when I ride that bike if it’s been a while
That’s very high pressure, how much do you weigh? Is that the recommendation for your weight? What width tyres? There’ll be a range on the side wall, if you’re heavy go near the top, light the bottom
and they’re tyres in London![]()
On my wheels it says espoir sport and axis sport on them.^^^WSS^^^
But as said upthread, 110 sounds high.
Before every ride. It's a two minute job, I wouldn't leave home without checking I was running on the correct pressure.For road bikes. The recommended pressure for my bike tires is 110PSI how often do I need to pump them?
