AndyRM
XOXO
- North Shields
So far it is only the two of us in Canada owning up to similar teenage errors: what can this mean?
Canadians are better at keeping secrets?
So true. I've done that myself with excellent results. Not recommended with a cheap toaster, you need one that will toast fat bread as it has wider slots.you just stick the toaster on its side and job's a good 'un
A few more than 3. Sometimes I very lightly toast the cheese side first, sometimes not. It all depends on the bread.YAY ! Someone else who does cheese on toast the 'right' way !Does that make 2 weirdos - or maybe 3 ?
That's a pizza...I sense a clique forming...!
I also put tomato on, or chopped spring onion, or BOTH, then... has to be chutney as accompaniment.
Nah! You just have to watch it like a hawk. I've always pre-empted the pop-upper and pressed the release button while holding the pushing down lever thingy.just realised that it might require a bit of skill / carefully placed plate if used with pop-up (or pop-sideways) toaster too
Well what I always say is: pizza is just cheese on toast really. All those restaurants and takeaways based on cheese on toast...That's a pizza...
Went out for a bike ride yesterday, leaving Son #2 on his own at home. He's 14
Son #2 "I fancy cheese on toast, how do I work the grill?" (we have a new kitchen with a new grill/oven thingy so that was a reasonable question)
Me: "blah, blah, blah.....see you in a couple of hours. Call me if you need anything"
Got home to find cheese on toast in the bin. And bits of cheese on the worksurfaces. Had a look around then I realised what had happened.
He'd got the grill thingy to work fine and loaded up the cheese on the bread.....but he didn't realise he had to toast the bread first. So ingenious person he is, he thought that the sensible thing to do would be to stick the bread (now with melted cheese on it) in the toaster. In it went. And out came the melted cheese, dripping out of the bottom of the toaster.
Result: Cheese on toast without much cheese left on it.....and a toaster full of melted orange goo
I hate to say this, but not putting metal objects into a switched on toaster (ever again) would be my first thought - surely you'd only need the RCD if you intended doing it regularly
(RCD are a "good thing" so "just sayin' like")
