Ridgeway
- Lausanne, Switzerland
Old thread resurrection alert:
I had to drop my commuter bike off at the LBS on Friday and they agreed to give me a loaner for this week. They quickly showed me the temp replacement bike and just mentioned it has ABS…..
You can guess my mission on the return trip home😂
Now although it was dry i did find some fine gravel/gritted areas where i tried to get the front wheel to loose it’s grip and was surprised to see what it could take. In a straight line the (dry road) the braking distance was certainly reduced but i guess on a slippery road surface whilst cornering and just touching the brakes the result would be the same, but then OK you’re on the edge of tyre grip anyway.
You can’t feel the brake modulation as it‘s so fast, probably all the play in the front end and tyre that absorbs it.
Interesting technical development that certainly has a place some where in cycling, commuting for sure with heavy bikes but not too sure after that ?
