kimble
We couldn't give a monkey's how you do it. So long as it's a bicycle. Motorbikes? off the agenda. But if you have a problem with it the TECs might not be able to fix it and that's a problem.
There will always be rare problems that are unfixable at the roadside. What does it matter if it's, say, a dicky hall sensor compared to a seatpost snapping, a lightweight wheel losing half its spokes, a swollen knee or asthmatic lungs that can't cope with the cold? As with anything else, you check the bike over and prove it's reasonably reliable before bringing it on a group ride, and accept that if it fails, it's your own problem.
(I'm not sure about this increasing perception of the TECs role being to fix bike problems. It's primarily about keeping the group together. Sure, providing an extra pair of hands when someone's dealing with a puncture can help with that, but aren't we ultimately supposed to be self-sufficient?)
If the bike and rider are proven to be up to the distance (the point about battery capacity at nighttime temperatures is a good one, and applies equally to things like lights and GPS receivers), then it's all good. In practical e-bike terms, that means you're either going to be hauling a massive battery or riding primarily under human power, and just using the assistance on the hills. Don't assume that you'll be able to recharge at the halfway stop without checking!
Also, this is blatant discrimination against three-wheelers.
). But every minute the back of the ride is delayed means another 75 people delayed for a minute at the front of the ride. The main need while fixing a mechanical is lighting, so three people pointing their bike lights or holding torches makes a big difference. And it's usually the case that it's much quicker for the bike owner to be rooting around in their bags for inner tubes and tyre levers while others get the wheel off, remove tyre, etc. And hardly anyone seems to carry a big strong Zefal pump capable of getting to 100 psi quickly. And once it's fixed the owner can be replacing kit in bags while others put wheel back on, etc. Because every minute the back of the ride is delayed means 75 others waiting for a minute at the front of the ride....
