New Tyres
MonsterEnergy
Hi
I am wanting to upgrade my Tyres on Carrera Vulcan Hardtail MTB, but wondering how to remove the back wheel so i can change the tyre.
Spiderweb
Not So Special One
North Yorkshire
Probably easier to watch a YouTube video than explain and understand.
MonsterEnergy
MonsterEnergy
Look here:
View: https://www.youtube.com/watch?v=2pnbJ64zvME
You will either have a quick-release or need a spanner if there's a nut instead. If it's not disc brake either let the tyre down or unclip the V-brake to get the tyre past the brakes.
i have a quick release like i do on the front, but just thinking of the chain and everything else next to it. What happens with that.
Or, do u literally just do the quick release and slide it out like the front?
DCLane
Put it in the highest gear at the back, lowest at the front so you've a lot of chain slack
Undo the quick release and slide the wheel out; the chain should be loose enough to simply move past the quick release and the rear derailleur
mjr
Probably, but you may have to push the bottom wheel of the derailleur (or the frame around it) down and then back (it moves in an arc below the top wheel) for the wheel to drop down and out on some bikes. Hang the saddle nose from something secure to keep the back end off the ground while you work on the back wheel. Or lie it down on the non-chain side. Never rest or drop the bike on its derailleur as that way expensive bending can result.
Make sure you refix the quick release lever correctly as shown in youtube videos. Parktools is a good repair website.
MonsterEnergy
MonsterEnergy
I have ripped my tyres of my old mtb because they are knackered and are wanting to get some new ones.
My MTB is trax, 24inch wheels, and wondering whether i would have to get trax tyres or whether i could get a different make of tyres but same size.
Anyone help me please
Thanks
