£55 postage free, similar I think to Ortliebs. excellent panniers
http://www.cyclesense.co.uk/products.php?plid=m24b139s74p6320
Application - to be mounted both to the bicycle's rear carrying rack.
Securo 680 - PVC-coated polyester fabric. Less durable than Cordura, but thanks to an ideally smooth surface is easier to maintain clean and completely water-proof.
Dry are made to be used where water is the dominant element. They dread no downpours or crossing rushing streams. Coated on both sides, the Securo 680 material not only doesn't leak water, but it doesn't absorb it at all! The pannier panels are welded, which is why there is no problem with leaks on the seams, as there aren't any seams. Additional advantages of the Dry series include the attractive price, low weight and very large capacity.
Material: Securo 680
Capacity: 60 litres (whole set)
Weight: 1650 g (whole set)
Construction:
· Capacious main chamber,
· Stiffening from the side of the wheel with non-breakable polypropylene board 3 mm in thickness w shape memory,
· Seams precisely welded, completely water-proof,
· Tight, rolled closing,
· Nylon non-breakable clamps,
· Fluorescent elements visible even at 600 m,
· Comfortable handle for carrying,
· Steel fittings (hooks), with double zinc-coating, 2 mm in thickness,
· Well performing load-bearing system.
Dimensions:
· Base width - 27 cm,
· Width - 38 cm,
· Height after triple roll-up - 42 cm,
· Thickness - 16 cm,
· Spacing of hooks - 21.5 cm
Weight 1650g (whole set)
Sold in pairs
