Dogtrousers
Lefty tighty. Get it righty.
Well ... yes and no.I think that most modern cyclist been a bit brainwashed by the trickle down from racing and don't really know better.
When I started I had 3x5 gears with a range of roughly 3x.
Top gear was from just over 100" down to roughly 35".
So I had to pick my own gears with care.
Now 2x10 with a range of 4.5x is standard.
In the same time the big chainring went from 53t to 50t and sprockets from 14t to 11t.
So top gear is roughly 20% higher but the greater range means that the lowest gears is also around 20% lower.
So there is lot less need to pick your own gears.
Once you start to look beyond "bog standard" gears then you start to realize how bad the "bog standard" gears are for average riders.
How many normal riders need to cycle downhill at +35 mph .........
But if you shrink all the "bog standard" gears by roughly 10%-20% to shift the gears to a more useful range then you'll probably fall into a marketing disaster because that implies that you're not good enough to use racing gears.
Hence the brainwashing from racing.
YMMV .........![]()
As you say, the "bog standard range" is now much wider. 50/34 11-32 - which is probably the commonest on new bikes is 28" to 120" (or thereabouts )
That's not "bad" by anyone's estimation, although it's true that most normal riders don't need the top two little 11 & 12T sprockets, it's certainly close to one size fits all, and that's what the industry likes. It means fewer different parts.
I think your brainwashing theory is just a tad patronising. I doubt anyone, or very very few, purchasers would turn down a bike because it would mean they are "not good enough to use racing gears". They are probably more concerned with "will I be able to get up that big hill and avoid walking".
I agree that things would probably be even more suitable for the average rider if the chainring size came down a little, but as it stands the "bog standard range" is pretty good.
I love playing around with spreadsheets, and by using GPS and cadence data I know exactly how much I use my 11T sprocket. It's not very often at all. But I don't resent its presence. On the contrary, I quite like it - especially for the long gentle descent off the N Downs at the end of some of my rides. I freewheel most of the way and top it up occasionally with a few slow revs in top gear.
