Rain drops
Aluminium frames appear to be resurgent in challenge to carbon fibre frames, in both light weight, and compliance. Is this sensible with regard to durability, and longevity? Aluminium has problems in situations where it is subject to continual flexing, which leads to fatigue failure. (Sudden snapping.) Those of us into sea sports (windsurfing in particular) were continually having to replace alloy booms (built to unavoidably flex somewhat) on nearly a yearly basis, and blessed the day composites (carbon fibre) took their place. Carbon fibre, provided it does not exceed its design limits of flexing, is almost impervious to fatigue.
It will be interesting to see if these lightweight alloy bikes with higher compliance (comfort) now challenging the role of carbon fibre (why, for goodness sake?) are indeed long lasting and durable? I would assume not! I used a Boardman Comp (£600) road bike originally but laid it up after 5 years use for fear of fatigue failure around the welds of the bottom bracket area. The current pair of carbon fibre bikes should be impervious to fatigue, apart crash failure, and should see me out.
M.T.B.'s successfully use alloy frames but they are not subject to smoothing compliance in that the full suspension plays that role, and the frames can be kept rigid. I see no downside in their design.
