Trebz
Hi all
Onto my next project, converting the Raleigh Record Sprint shown below into a fixed gear or a single speed.
The bike is now stripped down to component level. All original standard components including the wheels will be sold off via Ebay or similar in order to part fund the rest of the re build.
The frame will be sent off for powder coating when I have decided on a colour scheme, so far I have my heart set on a silver / black scheme. This being built up of black frame with polished aluminium where possible. The original Raleigh steerer tube badge has been retained and will be re fitted.
My plan is to re build the bike as light as possible without breaking the bank. I am however stuck on a few things due to my being out of the loop for some time.
1. Headset size. I measure the steerer tube at 30mm, is this the correct size to use when buying the headset.
2. Bottom bracket size, I measure the bottom bracket size to be 34mm, is this the correct size to use when buying the bottom bracket. Also what about BB width, I know i need to bear in mind chain alignment.
3. Seat stem size, I measure the seat stem size to be 27mm, is this the correct size to use when buying a seat stem.
4. Wheels, I am a total loss when looking at wheels, I want polished or black with a fixed rear or freewheel. I do not want to fit the new 'Trendy' deep walled rims, I'd like the bike to retain a degree of the 'Old School' look. I need advice on wheel sizing etc, I measure the back wheel at 130mm and the front at about 95mm. Does this sound correct. Seriously, I need more help with the wheels than anything else.
The 'Want List' so far is:
1. Campag headset (Can you suggest some light ones or an alternative to Campag).
2. Campag bottom bracket, only choosing this as i remember them being light. Feel free to suggest an alternative.
3. Quill bar stem, polished.
4. Polished seat stem, maybe a Shimano 600. Fluted.
5. A chainset with an old school look, similar to the Stronglight range but with replaceable chain rings.
6. Wheels, see above noob comments.
I'll gladly document the build for all to see. Therefore putting something back into the forum for other to use in the future.
Thanks in advance ladies and gentlemen.
Regards
Trebz
Regards
Trebz
