I`m right in thinking that the Shimano biopace chain rings are out out of normal cirlular shape around the circumference of the ring and it would be ok to fit a normal circular chain ring?
Yeh! I never use the two smaller rings( I`ve fitted an electric kit to the bike) I`ve been getting a bit of knee trouble and have read that the biopace can sometimes cause it so I thought i would just try a standard ring to give it a try.
Biopace rings use a regular circular bolt pattern. There are no issues with mixing and matching rings of different ovality except that it feels decidedly odd. Avoid Biopace if at all possible, it was abandoned as a concept for good reason: it's sh!te.
Oh, back to the OP, have a look at that article for the comments on knee problems as well. The way in which Biopace are elliptical is the opposite to other elliptical chainrings, so it should be easier on the knees.
