hackbike 6 said:He did say he was riding in primary.
it isn't always the answer.IMHO.
As we have seen in this thread it can lead to an impatient motorist taking a risk to get past the cyclist in primary position.A close dangerous overtake.
TwickenhamCyclist said:Sorry to hear this – think police action is pointless – even with an “independent” witness – they will do sweet fa- well done for not loosing it – I’d of retaliated – suppose that makes you a better person than me
domtyler said:I would say that one of the main advantages of being in primary is that it gives you space to escape, room to make evasive manoeuvres in the event of dangerous driving from other people.
In this case, Chris had moved from primary into secondary giving the driver the green light to overtake even though it was not safe to. As he was also now in a weaker position he did not have room to take that evasive action.
If Chris had resisted the pressure to move out the way his position may have prevented the dangerous manoeuvre in the first place or, even if it had taken place, he could easily have braked and moved left out of the way in order to avoid any contact.
ChrisKH said:Possibly dom. Are you saying I should have kept primary all the way up the hill though?
Mr Pig said:I'd report it. Maybe the cops will do sod all, like they usually do, but even if they just talk to him it might be enough to stop him trying it again.
FatFellaFromFelixstowe said:It depends on the width of the road.
domtyler said:Wrong, it depends only on what is safe[st] for the cyclist. Holding up traffic behind you is a shame for them but unavoidable in some situations.
however I don't think that just because primary position is there then you have to ride in it at all times.FatFellaFromFelixstowe said:If the road is wide enough to ride in secondary then secondary is fine as long as it is safe. I also don't really care who I hold up when in primary and if someone honks their horn then I will cycle slowerhowever I don't think that just because primary position is there then you have to ride in it at all times.
"I always pull from primary to secondary position at that point as it's uphill from thereon and it's at that point he overtook me. I was a metre from the kerb but he couldn't get past because of oncoming traffic hence no room between us when he did pass."
domtyler said:The best way to analyse it is to ask:
Would you change what you did if you were in the same position tonight?
domtyler said:Yes, you're right, but Chris has already said that there was oncoming traffic:
I always stick to a default primary, it always seems that the moment you relax and move into secondary in order to let people behind overtake you get some lunatic manoeuvre that makes you wish you hadn't have bothered. When you do hit a nice straight stretch where there are no sideroads, pedestrians or other hazards then of course I move across too.
In this particular instance, given the information I have I would say Chris should have remained in primary until there was no oncoming traffic.
