Made from melted Poundland candles
Could be although seeing as based in US then unlikely. Maybe Walmart value brand or similar.
Wax is wax, fancier ones just have additives to smell nice
Yes, but it doesn't perform as well in wet conditions - starting to squeak earlier and requiring more frequent waxing as a result. I'm not sure if this is because the water causes the wax to migrate away faster from the contact surfaces, the water is aiding contamination ingress into these areas or a combination of both.Do you old hands use waxed chains all year round?
Supplementary Q: For rewaxing, how do you clean first? A full deep clean or is it just wipe with popranol (isopropyl alcohol) and rewax? - Or boiling water And dry? (as I’ve seen elsewhere)
Indeed.. I can't help but think this is yet another simple, cheap process being packaged up, branded and sold on at exorbitant cost.Marketing man's dream.
Bit like why do we bother with cycle specific clothing, GPS units, drinks bottles etc etc.
FWIW my waxing gear consists of a pan I picked up for nothing, a kilo of paraffin wax for £8, some moly powder (£12.50 for a load more than I've so-far used in eight years, and something I'm not sure I'd bother with again) and some hangers made from bent spokes...
Fair point about the cost and I can appreciate where you're coming from; having let myself off the lead a little in this regard recently.Yes of course using a specific bike hot wax pot and wax etc is more expensive but I can afford it so why not pay for the convenience.
We could use cheap alternatives but at this stage in life I'll treat myself.
I recall when I started road cycling I said I wouldn't bother with a GPS unit, HRM etc etc and here we are....
That said I still expect stuff to be reasonable value even if a bit of an indulgence; and I'm yet to be convinced by the wax at £80/kg...
I would argue that some of the other stuff you mention brings more tangible benefits to the table - technical clothing being far more comfortable (in terms of heat / sweat management and fit) and water bottles being pretty much a necessity!
I always thought I wouldn't bother with hot wax just stick (ba-boom!) with Squirt but seeing as new bike on way with of course new drivetrain etc I thought why not. I intend to only ride new bike in the dry and ride old in wet so wax should last etc.
I used to re-use the Shimano ones; probably 3-5 times before the 'click' on connecting became less convincing. I switched to the Connex ones as they are very easy indeed to connect / disconnect and that means that there is no impediment to waxing when doing so is marginal. It's also very handy for just taking the chain off whenever doing maintenance. They are 'not cheap', but then my chains are now lasting about 15,000km so it's hardly a lot over that distance.
