GrasB
- Nr Cambridge
So from what I can tell there are 4 ways to do disc brakes with a single speed.
There are chain tug disc adaptors, but due to the forces involved imo they're a non starter & I'll be avoiding them.
Vertical dropouts provide the best solution for maintaining correct disc/caliper alignment without re-adjustment if you want to change the gearing. The most well known is vertical dropout solusion is to use a chain tensioner such as the Gusset Bachelor SS. While they certainly do work as it's the tensioning method I used on the MTB IMO it's a kludge at best to solve a problem of using an existing frame & as this won't be an existing frame I don't want to use it.
The other thing that could be done with vertical drop outs is the use of an eccentric bottom bracket, having never used or seen one in the flesh is this a good solution to the tension problem?
Finally there's the solution used by on-one & cotic, horizontal dropouts with disc mountings which allow for the caliper to be moved. While this does have the advantage of allowing for more chain adjustment it also could be fiddly to get everything aligned properly.
So out of the 3 options I'm willing to consider which do people think are best & why?
