Solar Production Thread
Deleted member 26715
The battery is still half full after running the house overnight. Weather is a bit grim today, will be interesting to see how much charge the battery picks up from the panels, if any.
That's brilliant, ours ends up each morning less that 10%, currently 7%, just looking it was depleted before 11pm last night, which is a little unusual it's normally 2am before it empties, but we used the cooker & washer after the sun went down.
J
jowwy
Can't spell, Can't Punctuate....Sue Me
My installation documents will be with me in 2 days....so can set-up the octopus outgoing then, we wont export much at this time of the year......but as tesco says " every little helps"
kipster
Hampshire
I'm expecting my electric and gas bills today, and fingers crossed my export credit. It will all help inform me what my direct debit should be set to moving forward. I haven't changed it since I had solar installed so have built up quite a credit with Octopus.
Alex321
South Wales
If ours reached full charge during the day, it usually drops to something in the 60's overnight.
It has turned sunny here now, and it is charging up again, with 4.54kW being generated and only 680W being used.
kipster
Hampshire
Cloudy here at the moment. Battery down to 16%, I drink too much tea and the dishwasher and washing machine are on.
Producing 410w and consuming 410w
J
jowwy
still raining up here in the mountains :sad:
It's addictive, the rain has currently stopped & were up to 320W, but the grandkids have arrived so the TV has gone on so we're still in negative, but less so if we didn't have the panels
kipster
Hampshire
Only 8.2kWh today, didn't even charge the battery very much so will be importing from the grid later :sad:
4.1kWh we might just see 4.2kWh, but we're already onto the battery which is below 20% so definitely going to be gridding, probably just to cook tea.
kipster
Hampshire
Anybody else on Octopus signed up for the Savings sessions? I got an invite today so signed up. I don't think it'll amount to much due to solar and not using much from the grid so not much to save.
Just arrived in my inbox, not opened it yet
Hebe
getting better all the time
wiltshire
About 5.5 kwh, thanks to some late afternoon sunshine. Got the battery up to 61% but it’s discharging now while I use the oven. Weather looks a bit better tomorrow.
A question for you Solar peeps.
We currently use about 9Kwh a day for the house and about 10Kwh for the car - so 19 total.
Is it possible to charge the car direct from the Grid at night and not from say your battery attached to the solar ? As then I'd pretty much be able to run the house off of the stored electric on a good day and not have to import so much ?
We would be looking at getting a 10kwh battery and I believe a 3.5 or 4kwh panel array.
kipster
Hampshire
Are you with octopus? They have an octopus Go and intelligent octopus tariffs for EVs and you can charge up overnight for on cheaper rates than normal (12p a kwh for go and 10p on intelligent octopus) If you also get solar batteries you can also charge them overnight on the same tariff. The solar batteries can also charge from the panels but it would be beneficial to charge the batteries from the grid overnight as well.
I don't have an EV so not on either of those tariffs
