I guess you meant front loader but no it doesn't. Our Bosch is designed to run on very little water and as far as I know the water level is never enough to spill out. I've had it 2 years and can only recall one occasion when I couldn't open the door to pop something else in. The benefits of a modern machine are significant. For example I can wash a full set of winter cycling gear, socks, bib shorts, bib longs, base layer (possibly two), winter jersey/jacket in 15 minutes and it comes out dry to the point where ten minutes in front of a radiator and it's fully dry.
You mentioned plumbing in. All that is required is a cold water inlet feed and waste water out, it's two minute job to connect presuming the plumbing is there which it should be in any property that's been in anyway modernised.
