GrasB
- Nr Cambridge
Kinda immaterial, as the compact setup gives more gears across a marginally higher & wider ratio set.MacB said:I think he meant to say lazy AND weak, not or![]()
jimboalee said:
Today, newbie buyers of bikes don't seem to have the time or willpower to become a 'half decent' cyclist by the 'ride up grades, don't ride upgrades' method, so we see Compacts and Triples on Roadrace bikes.
To old codgers like me, a Roadrace bike without a 53 ring or with a triple, is the sign of either a lazy or weak cyclist.
GregCollins said:Great post. Don't the gears you need vary with the load you are carrying and to a lesser degree the strength of your legs?
Bloke said:I personally couldn't give a fiddlers for what others think of my achievements or my gearing, I just want to enjoy my cycling on a bike that's ideally set up for me & the way I ride. I love spinning a constant hummingbird cadence and adjusting my pace incrementally and constantly with my gears. I live in the foothills of the Dublin and Wicklow "mountains" so I actually can't go for a spin without encountering hills, which suits me cos I like 'em and consider them great value-for-time-spent training. If I'm on a flat or rolling ride I'm on the gears all the time, spinning at my highest comfortable cadence, so I hate the fact that when I hit a steep hill my only option is to clunk into 1st and slog in the saddle or stand on the pedals. I'd dearly love to have lower ratios to play with, keep my cadence up and climb the hill faster and more efficiently as a result.![]()
jimboalee said:To expand on this theme.
For choosing the low gears, there is an old bit of witchcraft which is so simple, it defies belief.
It is however, based around a 'half decent' cyclist.
In years gone by, the gears would be fitted, the rider told where the hills are and it wouldn't be long before he became a 'half decent' cyclist.
jimboalee said:Serious now.
Let’s take the favourite 10% gradient.
For example, a cyclist rides along at 18.5 mph and is putting 200 Watts into it.
Climbing up the 10%, his speed will reduce to one third ( 6.2 mph ) and the power required will approximately increase by 50% to 300 Watts.
What gear is required to ride at 6.2 mph at 80 cadence? It happens to be 27” or a 28 chainring to 28 sprocket 1:1 ratio.
How many ROAD bikes have this gear? Only very recent ones where the manufacturers have identified their customers haven’t much cycling experience.
The normal situation is that a 10% hill will be climbed in something like a 40” gear, 30 ring to 20 sprocket, or 39 ring to 27 sprocket, or other combinations with 34, 36 and 38 tooth chainrings.
So does it matter what size chainring the bike has?
Let’s go mental and try a 20 % hill.
Speed will be something like 3 mph at 300 Watts into the cranks. The bike will need a gear down at 21”, or 28 ring and 36 sprocket for the rider to turn the cranks at 50 rpm.
Only Touring and MTBs have these kind of gears.
Roadies are seen struggling at 35 rpm on a 30 ring and 27 sprocket.
Climbing up hills steeper that 8% at 80 cadence is really ‘out of the question’ on a road bike, even one with a 30 ring and 27 sprocket.
And the way to have a 30 tooth chainring, is to fit a triple.
bhoyjim said:That must be where i'm going wrong Jimbo, i have none of the above combo's on my road bike (30,42,52) (12-25) so that explains why i'm crap going up hills.
Me too
