OK, you both lose a mark for not properly defining your terms, but what I'm more interested in is the chemical reaction between rubber and tarmac. How does that work then?
That's stretching the definition of 'chemical reaction' more than just a little. There are plenty of definitions out there, but this one is reasonable ....That's the thing that makes the tyre work. It's a base principle, without it, the tyre can't work. I could go hunting for the relavant abstracts, but I can't be arsed.
So if I can cycle fast enough in the rain, I should fit car tyres. Would the panel recommend radial or cross-ply?
As @Bollo says, there is no chemical reaction between the tyre and the road surface.That's the thing that makes the tyre work. It's a base principle, without it, the tyre can't work. I could go hunting for the relavant abstracts, but I can't be arsed.
No further questions.That's the thing that makes the tyre work. It's a base principle, without it, the tyre can't work. I could go hunting for the relavant abstracts, but I can't be arsed.
Do some reading on 'surface chemistry' come back in about 3 to 4 years, see if your opinion has changed. And see just how wrong what you just posted actually is.That's stretching the definition of 'chemical reaction' more than just a little. There are plenty of definitions out there, but this one is reasonable ....
"a process that involves rearrangement of the molecular or ionic structure of a substance"
The tyre rubber does not become something else. The tarmac does not become something else. The grip is provided by the physical interface between tyre and tarmac (with maybe some water in the way if it's wet). For cycling at least, the heat generated by the action of friction on tyre and tarmac won't be enough to change the chemical composition of either. Even if bits of the tyre wear away, that's no more a chemical reaction than me hitting a banana with a hammer is a chemical reaction.
You have no idea how wrong you are. Have a scout about on 'surface chemistry' and the interactions between rubber tyre compounds and tarmac. I'll see you in a few years, or not.As @Bollo says, there is no chemical reaction between the tyre and the road surface.
The tyre compound changes its grip characteristics due to it heating up through friction and distortion.
Good, there's only so much casting of pearls before swine, and head into wall banging I'm going to do.No further questions.
I'm sorry, I really don't have the time or inclination.You have no idea how wrong you are. Have a scout about on 'surface chemistry' and the interactions between rubber tyre compounds and tarmac. I'll see you in a few years, or not.
There is no chemical reaction. What causes friction is a phenomena in physical chemistry. It is a polar attraction between the molecules of the two substances and NOT a chemical REACTION. I think I have already explained - Van der Waal's force.OK, you both lose a mark for not properly defining your terms, but what I'm more interested in is the chemical reaction between rubber and tarmac. How does that work then?
No, for that you'll have to get an education. That's not my problem.I'm sorry, I really don't have the time or inclination.
As you are no doubt an expert in this field, maybe you could explain it for those of us who don't have this knowledge.
