Ok thanks...I'm guessing that adds up to a less sturdy frame then right?
Not particularly, the results are still strong but imho its using a old manufacturing process of effectively joining tubes.
One of the advantages of Carbon fibre construction is the ability to change the characteristics of the material with the lay up, when you are joining pre-formed shapes you are limited by the sections you have at your disposal. It is also harder to create bikes with complex areo shapes using this process.
This is why the majority of the frames have a traditional appearance and the tubes do not feature bends on the top tube, or shaped head tubes, Even the Time Trial bikes have at best flattened tubes. Compared to bikes from other manufacturers the shapes are not so adventurous
There is nothing physically bad about making bikes in this way, its my perception of the process which makes me not like it. IMHO I think its a cheap process which requires less investment from the company involved, I have concerns about quality control when the company is dependent up buying carbon tubing/pre-formed sections from a third party and assembling them.
