Thanks - you can read about it
here. It was a project done on a shoestring using bits and pieces; the stem was one I had lying about.
That's really cool. I like the way you were able to replace the 26" wheels with 700c.
I wonder if I could do the same on this bike. Somebody donated it to me because it was unrideable. I managed to do the following and now it rides perfectly.
- non-drive side crank hanging off, needed replacing. Wrong bolts had been used to secure it; replaced with correct bolt
- replaced pedal with some old 2nd-hand ones.
- added dust covers once cranks fixed
- full bottom bracket service, replaced bearings.
- serviced both wheel hubs
- removed, cleaned and serviced freewheel and drivetrain.
- saddle adjusted
- derailleur hanger missing screw/fixing to connect with frame (found spare in box of bits)
- trued/cleaned both wheels
- put talc on innertubes
- serviced brakes and gear inner cables
- re-indexed gears
- missing nibbles on end of several cables. Replaced where necessary
It now rides beautifully and makes a great rat-bike. I might do a DIY custom paint job on it (a la
@betty swollocks) but just using masking tape and some cans of spray paint.
