You are of course right.
@RideLikeTheStig . This topic has been debated here ad infinitum and I don't want to rehash it again, even if it is now technically a year since the last big wheel fight here. My advice is thus:
1) Stick with the wheels. For the cost of a few bearings every year or so, just stick with them. The AC freehub is easy to service, the bearings are easy to replace yourself and the wheels are no better or worse than most high-end lightweight wheels. Go for a ride and forget about the wheels.
2) Once they wear out or the next repair involves a new rim, bin them. Then have someone like
@Spoked Wheels build you a set of standard wheels based on standard spokes, hubs and rims which will have a long service life and requires standard (i.e. non-proprietary) spares.
Fussing about wheels is a bit like a teenager fussing over the colour of his Subaru WRXZWY brake calipers. It is pointless.[/USER][/QUOTE][/QUOTE]
Took off the front wheel to try to find out what bearings I will need. I was able to get one end cap off but not the other. Does the end cap on the non drive side need to be knocked out using some sort of punch? Cant see how I can remove it.
