ayceejay
- Rural Quebec
You need one of these http://www.velosolo.co.uk/vstool.html
or one of these which may be better as it is longer therefore more leverage.
Incidentally the technique is to pull the chain tight then tighten the non drive side with the tyre touching the chain stay on that side
the chain will slacken some but when you pull the wheel straight and yighten the nut on the other side you should be good to go.
Re tighten after a few miles.
