stearman65
- Southport Merseyside UK
Do you mean rigid, no suspension? If so yes it is. I think it's around 2012?Nice. Is that the unsuspended model?
This is part of the text from the Ebay add "I recently put on a new tyre (a Schwalbe marathon plus, matching the rest). It's also got a pretty new chain and rear derailleur as well as SRAM X5 27 gears, triple front chain ring, X rims by Alex and Tektro brake levers.) I assume the pictures were pre add, I'll ask when I collect today, someone also mentioned the brake levers were upside down, which I assume was pre add & before the re-furb because it certainly didn't look the same when I saw it 2 days ago. Will post up to date images later.Whether it's the angle of the photo but the derailleur looks very close to the ground in the first photo whereas @SatNavSaysStraightOn 's one looks to be a shorter one.
26" rear wheel on @SatNavSaysStraightOn s trike whereas the other one looks to be a 20" rear wheel.Whether it's the angle of the photo but the derailleur looks very close to the ground in the first photo whereas @SatNavSaysStraightOn 's one looks to be a shorter one.
Mine was built by a professional trike builder. If you look at my brake levers you will find they are they same way up. Click on the image and it should enlarge. Look at the ice adventure website (http://www.icetrikes.co/explore-our-trikes/adventure) and you will also find they are they way up., someone also mentioned the brake levers were upside down
Ah yes... Still looks to be a short cage on @SatNavSaysStraightOn though.26" rear wheel on @SatNavSaysStraightOn s trike whereas the other one looks to be a 20" rear wheel.
I utilised my existing treat wheel with rohloff hub. The derailleur is there simply for chain tension as a result of the front derailleur and triple chain ring.26" rear wheel on @SatNavSaysStraightOn s trike whereas the other one looks to be a 20" rear wheel.
I've since changed it to a much longer one because of the chain constantly coming off when I changed chainrings on the frontAh yes... Still looks to be a short cage on @SatNavSaysStraightOn though.
20 inch all round.26" rear wheel on @SatNavSaysStraightOn s trike whereas the other one looks to be a 20" rear wheel.
