Uncle Phil said:You won't notice 270 g by the time you've put on tyres, tubes and rim tapes. You'd save more weight by taking a leak before you set off - and that won't cost you £200.
that's what i thought.kyuss said:That's pretty damned heavy. For comparison a pair of Halo Aerorage Track wheels will cost you £150 (£133 if you get them from Chain Reaction but they don't have stock at the moment) and they weigh in at 980gm for the front and 1045gm for the rear. Not exactly featherweight but that's a whole 1lb lighter and most of that weight loss will be at the rim where it matters most.
ok nice one, cheers - i might have a look at those.kyuss said:The Planet X track wheels look like a bargain at under £100. I know a few people who rate their track hubs as a budget option and the rims are the same as those used on their road wheels which are pretty light and get good reviews. These might even be lighter than the Halo's.
kyuss said:I'd disagree with that. If that weight was off the frame I might agree but weight off the wheels is the one place that you really really notice the difference especially if it's at the rims.
A bit of research shows those Weinmann rims to be really really heavy. They are cheap copies of the Rigida DP18 which themselves come in at 570 each which is fairly heavy. A Mavic CXP33 for instance (which is still a fairly deep rim) is almost 100gm lighter.
I couldn't find figures on Weinmann's own site for weights but the hubs used on the Weinmann build are Formula which according to Sheldon are the same as his own brand Harris Cyclery ones coming in at 275 for the front and 330 for the rear. The weights on the Formula site seem to confirm this. Average weight of 64 DT plain gauge spokes going by info from their site is about 320gm, or 160gsm per wheel. Let's be on the safe side and call it 200gm. That means those Weinmann rims are well over 700gm each.I wouldn't like to try and spin those up to speed.
Uncle Phil said:I bow to your superior knowledge on rims, then, Kyuss.
I hadn't seen the weight figures, but you're right - the difference is over a kilo, and in the rim, where it counts. I thought it was only a couple of hundred grams, which I don't think anyone would really notice, even in rims, unless they were to do a very careful side-by-side road test.
On the other hand, Bonj wanted: cheap, large-flange hubs, black, deep-section rims and radial spokes. I found him four out of five, which ain't bad - and he never said he wanted 'em light as well!![]()
Sensible price, too. Unfortunately the rims are not machined according to Ribble.Frustruck said:ASC, set of Navigator Pistas? Ribble and others do them, they look pretty good and have good bearings
kyuss said:...
kyuss said:Sorry, I didn't mean to come over all knowledgable.
Joe24 said:Bonj, get that old frame, put some Velocity Deep V rims on with some high flange hubs, really narrow handlebars that are narrower then your hips, run it brakeless and just use that to get about on. Who will nick that? Bang up the paint on it aswell, make it look real cool
I personally have front and rear brakes on my fixed, there are some big hills around here and if i take it into Derbyshire even bigger. Only use the front at the moment though.
bonj said:kyuss - do you think the front one of those planet x track wheels will be ok for a braking surface?
