Hi
Im absolutely useless with plumbing and could do with a little advice. My toilet cistern has the annoying habit of not stopping when refilling. Its the type that has two buttons on the top for a long/short flush. The problem only seems to occasionally occur in the morning. The water pressure were i live is very strong, and have noticed that the water entering the cistern via the valve assembly overwhelms it and jets out in all directions. When i turn the basin tap on the pressure naturally drops to toilet and the water enters properly.
I'm hedging my bets water pressure is alot higher in the early hours of the morning as nobody is up in the adjacent houses consuming water, and the higher pressure in turn is overloading the cistern. This to me seems logical as this problem only happens very early in the morning) (abait rarely). There is a small water isolation tap feeding the cistern. Should i just simply turn the pressure/flow rate down or am i barking up the wrong tree.
Sorry for my complete ignorance but i thought I'd ask the question here and get a more informed clue to what's wrong,
All the very best,
Johnny
All the very best,
Johnny
