Cyclist33
- Warrington
No, but batik is.
I agree, especially when overtaking a cyclist as any vehicles following won't necessarily be able to see the cyclist through the vehicle in front.I disagree.
It's important to give drivers of following vehicles notice that you may encroach further out into the lane than your current position, for whatever reason: parked car, narrowing road, kicked-out kerbs etc. The diagrams given in the HC show that, for example, a right indicator means 'I intend to move out to the right or turn right'.
GC
A competent, aware driver should know if there is a cyclist, driver or pedestrian who stands to benefit from his signal. He should also know if there's nobody around - whether he chooses to signal is up to him.
Signalling right going around a roundabout is one of the few signals you see that is (usually) trustworthy and useful. Saves you having to guess whether the driver is a prat who is signalling left for the next exit rather than you one you are in.I've also seen motorists that signal right when they're going straight on at a roundbout, before then signalling left as they exit.
Why in gods name they feel the need to signal right is beyond me.
Some people need sitting down and a good speaking to!
I often do a low arm out if I'm moving a little bit e.g. to go around a parked car - a kind of half indicate at 45 degrees or thereabouts.
Good/bad idea?
I'm with 400bhp on this one. A signal is to allow other road users to change their behaviour/direction/speed to avoid an accident or close encounter. No following motorist should be doing anything different whether a cyclists cuts off left or not. The only exception to this would be a car tailgating the cyclist, who you might hope would slow down if they saw a left signal. Chances are that the driver is a prat and would do no such thing and in that circumstance I would certainly be keeping my hands firmly on the handlebars.Sorry @400bhp but I disagree. this is akin to a driver telling me he couldn't fit past without a close pass. If you can make a move safely then don't make it at all. There is no excuse for not signalling, allowing yourself time to do so effectively is the key.
Unfortunately it is often the instictively indicating driver who says, 'but didn't you see me indicate?' as he climbs from the wreckage. Indicating needs to be thoughtful, not automatic.As per byegad I signal whenever required in the car, and as much as possible on the bike. The point for me is that it is possible to miss other road users and mirror/shouldercheck-signal-manoeuvre gives the other road user an opportunity to make their presence known or take appropriate action to avoid a coming together.
As a rider the indicator is a very useful guide to a driver's intentions and they can easily not have seen you, thus giving you a chance.
Bike or car, I think it's better to indicate even when you think there's no-one around just in case. It should just be instinctive, no effort required.
I No following motorist should be doing anything different whether a cyclists cuts off left or not. .
Maybe instinctive is not the best word for what I am trying to say.Unfortunately it is often the instictively indicating driver who says, 'but didn't you see me indicate?' as he climbs from the wreckage. Indicating needs to be thoughtful, not automatic.
I do this. I signal that I am not leaving at the first exit, and then I signal that I am leaving at the second exit. I think I was taught to do this, too. It depends on the size of the roundabout - if you can't see me before I get onto the the roundabout then "no signal" is ambiguous as you don't know where I've come from or where straight on might be.
The person who "sees people signalling when there's no one around" - well you're around, aren't you, otherwise you wouldn't see them signalling? I'm not a very good driver, maybe there's someone I should have noticed but have not who might find my singal useful - and it is no skin off my nose to flick an indicator lever! Signalling on a bike is different, of course, among other things you have to return your hand to the bars to change gear.
I live pretty much next to a large, multiple entry/exit roundabout and you really would not believe the number of drivers that signal left BEFORE the exit prior to the one they intend to exit at! The only solution is to ignore all signals and base your decisions on what vehicles actually physically do rather than the exhibited intentions!Signalling right going around a roundabout is one of the few signals you see that is (usually) trustworthy and useful. Saves you having to guess whether the driver is a prat who is signalling left for the next exit rather than you one you are in.
^^^^^^ this drives me nuts. You roll up to the lights at a dual lane junction, one car in the right lane, a dozen cars in the left lane. both lanes are marked as ok for straight on. Once the lights change to green the single car in the right lane starts to signal for a right turn! FFS, do these people have NO awareness or consideration?Those above who have said that when you signal you are indicating an intention are right on the money. My pet hate is pulling up behind someone at traffic lights who signals when the lights change denying you the opportunity to take another lane to avoid being held up. These are the same people who signal as they are turning, as if the flashers are connected to the steering wheel, surely there is no point at all in indicating at this point!
keep signals for turns and avoid confusion, thats my view.
