derrick
- On the edge of London
Sorted.
Nope t'is still working just added my 15 miles to it wi' nay bother.It WORKED ok on your iPad - it seems to change from minute to minute! Sometimes it works normally, sometimes it works very slowly, and often it doesn't work at all ...
I have started backing up my data after every ride, which is a bit of a pain.
Ha! Not working already....I spoke too soon.Nope t'is still working just added my 15 miles to it wi' nay bother.
Not working here either, must be a north/south divide
Yeah just managed to log last night's commute, won't need to use it again for a few daysJust tried again, still working, took a little while, but uploaded, then deleted ok.
Yes, that's something I try and use too, so it would certainly be retained.@TimO - if you do manage to do a CC version, one of the best features for me is the bike maintainance record information. It helps me work out how long components have lasted / when to plan maintainance.
The biggest problem for me, probably isn't the code to control the actual information itself, it's things like the CSS and how that relates to the look of the site, as well as Javascript for silly things like automagically inserting tags into that field when you click on recently used ones. It's not that I can't write Javascript (or more exactly "borrow" code, which I can then tweak!), it's the effort of making sure it works with as many browsers as possible. For that reason it may be slightly less user friendly initially, I'll err on the side of using HTML code that I know will work pretty much anywhere rather than trying to be too clever.
