Odd factoids
classic33
Leg End Member
The world’s most extensive and finest collection of cuckoo clocks (with both old and new models) is at the Cuckooland Museum in Cheshire, England.
The cuckoo clock, in its ‘modern’ form, was invented during the 16th century in Germany, and since has diversified into three main types: Black Forest, Swiss chalet and modern quartz.
Bonefish Blues
Banging donk
52 Festive Road
The Swiss cuckoo crock, as correctly termed originates from a rather remarkable duality of unusual occurrences.
Cuckoos suffer from vertigo, so only the little-known Plains Cuckoo (Spanish variety) is able to migrate to Switzerland. Sadly, because Switzerland is famous for its mountains, the Swiss have secretly folded up most of their Plains to make them, hence significantly reducing the habitat available to said cuckoo.
The above is exacerbated by the need for the Swiss to capture cuckoos in order to achieve their characteristic yodelling speech as the cuckoo, stuffed down their Swiss Army pants (regulation issue wear for every citizen in that highly-ordered & compliant society) pecks rhythmically at the gentleman's love sausage (thereby giving rise to the term pecker, incidentally) in order to achieve peak yodel.
Caught between these two rather remarkable instances, it's little wonder that the last Swiss cuckoo died in the late C19th. The Swiss nation was so overcome with grief that they created an industry out of horological cuckoo tributes to their part in their extinction (hence their correct name - cuckoo crock)
I guess it's obvious now I've explained it to you, but I'm rather surprised someone hasn't mention this already.
Here's your Swiss undies, should you come across a cuckoo looking as if it's at (or hankering to be at) a loose end:
https://www.ebay.co.uk/itm/2-x-Swis...arm-Underwear-Original-Military-/162957546591
Drago
The Urban Fringe
Anthropologists believe that Arnold Schwarzenegger is a male silver back gorilla, the offspring of a pair released by the Swiss Army from the Berlin zoo in 1945.
classic33
Leg End Member
"An employee of a luxury perfumes manufacturer has been awarded €40,000 in compensation by a French court after it was found to have inflicted extreme boredom on him, which amounted to harassment.
Frédéric Desnard had so little to do at his job – that he suffered from “bore-out”, which caused his health to deteriorate."
Drago
The Urban Fringe
Frederic Desnard now gets all the excitement he can handle at the landmine factory, where he works as a product tester.
