cd365
- Coventry, uk
100% the cyclists fault, how anyone can see it anyother way bemuses me. If he continues to ride like that he will end up dead with everyone blaming the moton
Just to point out that by the time the second bloke (blue top) went through the same gap, it was quite a bit wider - vehicles must have moved apart.
Or even the motorist!If he continues to ride like that he will end up dead with everyone blaming the moton
Maybe I’m just a big girl’s blouse, but unless I was absolutely certain it was one monumental traffic jam that wasn’t going anywhere for hours I would never position myself between a bus and a pickup, especially seeing as either could move at any moment – as for the gap being “quite a bit wider” – well compared to the first gap, even Victoria Beckham is quite a bit wider… still too risky for me
Now I'm really glad that my brakes are so much stronger than my legs! I knew there must a good reason for that.I've had a couple bad smashes from riding too fast to read the road ahead well enough
Marin..look at the road, at the lane markings and the metal studs. The bus is moving straight. But, quite clearly, everyone but you is wrong
You need to realize that it is a wide angled lens on the camera. Therfore things at the side of the picture appear to move more inwards the closer they get to the centre of the frame. You might as well blame the bus driver for shortening his vehicle as he moves off. Its part of the same optical effect.
