Planet X Titanium frame
Flandrien
Member
Frame came in today. She looks pretty! I was pleasantly surprised it has internal brake cabling as I always swear when cleaning the mud stuck between the brake hose and the downtube. I haven't tried it yet, but eyeballing and even measuring it, it seems 32mm tyres should fit.
Flandrien
Member
Internal cabling? That's another difference between V1 & V2
Yep, and Planet X's website still shows pictures with external cable guides. Go figure. But I'm actually
glad the downtube part is internal, the rest of the trajectory over the chainstay remains external.
sicknewt
Regular
Have you done any experiments with tyre sizes yet?
Flandrien
Member
I haven't built up the frame yet, but used the back wheel from my other disc bike, shod with Clement Strada Lgg 32mm, and it is a close call, but it does clear the frame. However, the wheel doesn't sit 100% straight in the frame and as such, the little rubber protrusions, which I guess are a remnant of the moulding of the rubber, hit the chainstay on one side, yet not on the other. I think this is shoddy QC from Planet X because it means the frame is not 100% straight. I'm sending it back. If your frame happened to be 100% straight, then you could put on a 32mm tryre, assuming your wheel is completely true, and it would clear the frame just enough not to hit the chainstays with the rubber threads on the side.
sicknewt
Regular
Ok, ta. Hope you get another frame sorted...
rogerzilla
Turn the wheel round first to check it's not just badly dished. If it is properly dished, the tyre will hit the frame on the same side as before. If it hits the frame on the other side, the wheel is (at least partly, possibly completely) at fault. Wheels are frequently out by a couple of millimetres.
sicknewt
Regular
