Sorry, you've lost me.Not just Cocks but magenta Cocks
Think he's referring to your irritating habit of a pale font. It's harder to read when scanning quickly as the contrast is reduced so I usually ignore your posts.Sorry, you've lost me.
RLJing cyclists are dangerous, they aren't just some benign form of stupidity. Being hit by a 200lb cyclist going at 15mph won't hurt as much as being hit by a car but it'll still hurt and could do real damage.Oh, a cyclist going through a red light is a dangerous idiot. A driver going across a junction without slowing slightly and being prepared to stop whilst checking it is clear is a more dangerous idiot.
Oh, a driver does have a legal obligation to only proceed through a junction if the way is clear.
I am not disputing that. A cyclist is a dangerous idiot who does it.RLJing cyclists are dangerous, they aren't just some benign form of stupidity. Being hit by a 200lb cyclist going at 15mph won't hurt as much as being hit by a car but it'll still hurt and could do real damage.
There is a tendency when discussing RLJing to almost excuse cyclists doing it because it's not as bad as a car doing it.
Nope. At a junction, slow a little and be prepared to stop.
20 is plenty, ( so I'm told ).I'd like to clarify this a bit with you if you don't mind?
So I am driving my car in a 30 zone and approach a crossroads with a set of traffic lights. The way ahead is clear and the lights are on green. They remain on green and I pass through the lights.
In those circumstances I'd probably slow down a bit approaching the lights in case they change to red. Let's say 20-25mph. But I wouldn't go any slower than that. I would definitely not go so slowly that, in the event of some vehicle jumping the red light, I'd be able to stop. I wouldn't see that vehicle until a few seconds before so I guess I'd have to pass through the junction at, say, 10mph
So, in a 30 zone what sort of speed are you advocating a driver proceed through a green light? I appreciate it depends on circumstances but perhaps a range may help me to understand your thinking
I heard similar from an advanced driving instructor years ago. He said the only colour light where you shouldn't be preparing to stop is red when you should be stopped already.My driving instructor years ago used to say, 'What's the only thing that can change about a green light?' You should approach them bearing in mind that the lights could suddenly change to red, in other words be prepared to stop. Whatever speed would allow you to do that safely in the space between you and the lights, that's the speed you should be doing.
It would depend on how hazardous the junction is. If it seems clear all around, then yes, a very little. If it;s busy and other vehicles are making it harder to see, then more. If there's lots of pedestrians around, again, a bit more. There's no fixed amount to slow but the more hazardous it is (reduced visibility and increase of the vulnerable) the more you should slow.I'd like to clarify this a bit with you if you don't mind?
At a speed of 20mph (9 m/s) the braking distance is12m (inlcuding thinking time). This translates to 2.5s to stop (if my sums are correct). In reality, paying atatention and better brakes these days, it's probably less than 2s
You're right, unfortunately. Most people are rushing to get through the lights before they change and hold them up for a moment or two on their seriously important journeys. Which is exactly the opposite of what people should be doing to ensure the safety of all of us, idiots or not.
Not sure it implies that at all. The speed that the OP may or may not normally drive through the lights is completely irrelevant. The point is that due to the traffic conditions the cyclist was lucky this time. If there is an implication to be made it is that sooner or later that luck is going to run out. There will be a body in a hospital bed or worse still on a slab and some poor sod living with the trauma of knocking the cyclist off his bike.Because the OP said that if he hadn't been going slowly he would have hit the cyclist. Which implies that the cyclist was lucky, because normally the OP wouldn't have been going so slowly. HTH.
