I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
Funnily enough, it was a Volvo that was getting on my nerves!
I was going to post the same. I mean, fancy having to trail cables the length of your frame. What a bodge!
I've only ever ridden one bike with Di2 and it was magnificent. Stopping on too high a gradient for the gear you're in? None of this lift rear wheel clack clack clack spin clack clack clack stuff; instead, buttery smooth transitions. Also, no indexing issues, cable stretch or misalignment after initial setup.
When it works it cannot be beaten.
Conversely I know someone who had an early model Di2 which died in the middle of a ride, they were stuck in the gear they had with no options for bodging.
THIS^^^^I agree.
Right now my kid wants me to sort out his Xbox account. So I'm working with tech at work, I had a small issue with tech at home, and now I'm still screwing around with tech sorting Xbox out. All I want to do is chill out for a bit. And this damn soft keyboard isn't helping matters.
All this constant on and on dealing with tech is getting crazy. I really don't know how to fix things that are not "tech" any more.
All very good I’m sure, but my gears never need charging, don’t need batteries and the cable won’t come adrift.Err,multiple shifts, self-trim of the front mech, sprint shifters to name three.
Oh and charge lasts for a good while with the current battery and you can always leave it on charge when not in use.
Renault Captur.I don’t drive a lot on motorways. Mainly rural.
Use it as much as possible.Cruise Control is not just for motorways I use mine most of the time especially in 30's
I'm not saying Di2 is not good, in fact I think it's great and Shimano done a splendid job so if anyone else wants to get it, I will warm heartedly recommend it.
The reason I won't get Di2 is because I don't want yet another device that does software updates, has a million configuration options, gets a software update and changes the menu items around.
Annoyance: I just spent 30 minutes trying to figure out how to adjust the volume of the beeps that come from the TV when I go muck around with the options. Someone had changed it but they didn't own up. Cycling is fun for me and I don't want to turn it into a flamin' techno fest. Grrrr.
I hate all that media-connected-to-phone stuff. Usually works first time then gets into a twist afterwards. If they can make it work reliably, even if it has less functions, I'm all for it .But all these xompcompawant to do is add more and more functions but not fix the existing bugs. Highly annoying .
Seems perfectly logical to me.So because of the fact that you couldn't sort your telly out, you don't want Di2 ?![]()
