Things You've Learnt From Fettling
bpsmith
Needed to fit a new lower headset bearing, so decided to finally cut down the steerer after riding with the stem a lot lower than when I first got the bike. The obvious thing was that the compression bung was in the way. After a short while scratching my head, it became clear how it all worked. I had put this job off for ages as though there would be a lot more to it.
What have you learnt from a spot of DIY fettling, the easy way or the hard way?
I like Skol
Hold my beer and watch this....
Don't mess with things I am not prepared/can't afford to ruin!
Hugh Manatee
Campagnolo rear hubs are very different to Shimano. I have serviced many, many Shimano hubs. Removing the cassette body and replacing bearings seems very logical and strait forward.
I assumed the big C would be similar. Wrong! Springs, pawls and bearings went everywhere. Managed eventually to get it all back together complete with new bearings.
The trick is to use a length of cotton to keep pawls in place as you reassemble. Luckily, Campagnolo hubs seem long lived and I haven't had to do them since.
byegad
NE England
My golden rules are:-
1. To only fettle when I don't need the bike urgently anytime soon.
2. Leave things that are working perfectly well alone!
3. Only start a job for which I already have the tools.
4. Use time spent lubricating, cleaning or tyre pumping to cast a glance over all of the components to spot trouble before it develops into a breakdown. A prime example would be spotting an accessory coming loose, or a fraying cable!
CanucksTraveller
Hertfordshire
Don't pull on a fraying cable with your bare hands, unless you like the idea of a sensation akin to needles going in your fingers.
Milkfloat
An Peanut
Midlands
I seemed to have learnt that you should buy everything required for a job at least 6 months before I actually perform the work. I think subconsciously I believe that allowing the parts and tools to mature will make everything easier. Either that or I like shopping more than fixing.
