Tiagra cassette removal tool?
digit
Hi all,
I have a Shimano Tiagra 10 spd cassette that I need to change.
I know I'll need a chain whip but which cassette removal tool?
would an FWE Shimano HG cassette removal tool work?
Cheers
digit
You'll need one of THESE, which TBH looks like the HG one you mentioned :okay:
Cycleops
Accra, Ghana
Should look like this.
digit
Thanks Smokey, Dan,
Cyclops, is the pin part for alignment? .... assume it goes where the skewer is removed from?
mcshroom
Bionic Subsonic
Yes the pin slots into the axle to stabilise the tool. I find it quite helpful on mine, but you don't need it.
T4tomo
A Shimano cassette tool is Shimano cassette tool, (see also Campag cassette tool, which is different) you also need an adjustable spanner to turn it against the chain whip
Loch side.
But may not have the spindle, it will still be OK without.
The spindle in the centre makes the tool far more stable, as suggested by mushroom boy. The tool is infinitely better with the spindle and the only reason you should own one without a spindle is if you have solid axles.
T4tomo
Or if you have friends or acquaintances who have solid axles and know "you're a dab hand with bike stuff" and want you to change their cassette. You can also use the skewer to secure your non spindle cassette tool before applying the spanner if it's being particularly resistant.
Tim Hall
Crawley
Mine has no spindle, but the central hole is large enough to fit over the axle. It is then held in place by the axle QR mechanism.
Loch side.
Let them buy their own stupid non-stable tools.
