Tanis8472
My head displaces water better without hair
https://www.sheldonbrown.com/gloss_ho-z.htmlNo, I don't think a slick tyre would displace water in the same way that a treaded tyre would.
What does the tyre tread do?
On a normal, smooth road, the tread has only limited influence on the riding properties. The grip generated by the tyre on the road is almost exclusively the result of the rubber compound.
Unlike a car, a bicycle will not aquaplane. The contact area is much smaller and the contact pressure is much higher. The floating effect of aquaplaning could only theoretically be achieved on a bicycle ridden at speeds over 200 km/h.
Off road though, the tread is very important. In this situation the tread establishes an interlocking cog-like connection with the ground and enables the transmission of all driving, braking and steering forces. On rough or dirty roads, the tread can also contribute to better control.
My kojaks have no tread. They work fine in the wet.
How is this possible without tread? Discuss.
Tread patterns are there to displace water and thereby increase the speed at which aquaplaning occurs on tyres that have a combination of factors ie. low enough contact pressure, large enough contact area with the road surface or high enough speed to induce it.I initially responded regarding a tread pattern on a tyre displacing water. Others have bought in aquaplaning.
Tread patterns are there to displace water and thereby increase the speed at which aquaplaning occurs on tyres that have a low enough contact pressure, large enough contact area with the road surface or high enough speed to induce it.
Bicycle tyres have none of the above criteria; tread is only there for aesthetics.
Do you, or anyone else, have any evidence that tread is necessary on road bike tyres?Not going to discuss an anecdote which is biased.
An untreaded tyre displaces water. A tyre made of smooth steel would displace water.No, I'd still say that a treaded tyre displaces water.
Yebbutt you want to displace water to prevent aquaplaning - which will happe if you can go fast enough,which you can't
