gazmercer
- Prescot, Merseyside
Decided to take a look at my back wheel today as it had started to wobble. I knew it was the cones, tried to sort it out but just couldn't get the freewheel off (I need a good vice or something). Anyway, I tightened up the cones on the none drive side a little and the wobble has gone but it's grinding a little (not got time to look at it anymore as I have to be in work soon, on the bike I'm fettling with).
Now the wheel had stopped wobbling I noticed it wasn't true. Out came the spoke key and off I went. OOPS !! Wheel went totally out. Called Halfords to see if it was covered under guarantee and they said it would cost £12 to true it or £35 if it was a new wheel. PAH, I said, stripped the tyre off the wheel (I had punctured the inner tube while messing with spokes earlier so it needed to be done).
Got an Allen key and some plasticine and fixed the Allen key to the frame, just scraping the wheel rim. Turned the wheel slowly and found the untrue section. Followed a section on Bikemagic on truing a wheel (White Apple Mac and Bike Oil don't mix too well either). Within an hour I had almost got it perfect. When I have more time I will take a proper look and see if I can get it even better.
All in all it turned out OK but after a few F*** ups. Not taken it for a test ride so hope none of the spokes break on me and there are no hops in the wheel.
Moral of the story, don't fettle with the bike you commute to work on especially hours before leaving.
I am going to get a bath and something to eat now. If you don't hear from me later I'll be in a ditch or something with a bike with one wheel
