Hi This is integrated cabling, might need you help. One is going to the LBS if a cable or hoses required work. Hidden cables will give the bike shops a nice little earner, was told my ORRO with the cables through the headset unit would be time consuming.I just built up my first frame with integrated cables (and a press fit BB 🤣) and although it took longer, it was no where near as difficult as I anticipated it to be. The results are worth it, the frame looks so clean without any cabling.
Recently changed headset bearings in one of those, Nice little earner.Hi This is integrated cabling, might need you help. One is going to the LBS if a cable or hoses required work. Hidden cables will give the bike shops a nice little earner, was told my ORRO with the cables through the headset unit would be time consuming. View attachment 638710
Don't you just love clean lines on a bike, that is until it needs fixed😩
I have a problem with not trusting my LBS or shop people in general. I see the transactions they and I might have in a game-theoretic way. That is, our goals are opposite: theirs is to maximise profit and mine, to minimise cost. Yet we sometimes need to cooperate to achieve our separate, incompatible goals and come out with a result we can both live with.
Looks like it might be a bit of a orro story.Hi This is integrated cabling, might need you help. One is going to the LBS if a cable or hoses required work. Hidden cables will give the bike shops a nice little earner, was told my ORRO with the cables through the headset unit would be time consuming.
Often buy parts and ask LBS to fit. Mine just charges an extra fiver on top of their standard fitting rates if the customer supplies the part![]()
