I find A flat to be particularly fatiguing.Coupled with knowing which frequencies people tend to find more fatiguing, that could be very relevant here.
titanium picks up on titanium and if this happens you have a big problem, I have had titanium collars pick up on titanium shafts on several occasions, the trick for both Aluminium & Ti is cleanliness & the right anti scuffing paste, I only use carbon posts in my Ti frames.
The statements in bold are of course very sweeping generalisations .... and are not without substance, BUT.utter bollox. You obviously do not actually ride bikes..Alu bikes are very rigid and unforgiving, Steel frames flex and spring, carbon - I can't comment on as I don't have experience as a rider.
I still treasure Mickle's description of the place;They can be superb. I ordered rims and spokes from them. A few days later I got a phone call asking what the hub was because the numbers didn't fit anything they used. I explained what it was, he checked and agreed it was OK.
The shop is something of a legend. I've known about them for years but only recently had the opportunity to drop in. I was somewhat taken aback by the appearance - the window display appears not to have been changed in years, full of old crap. Old crap which had a thick layer of dust on it.
You walk in to an area which looks like someones front room has been turned into a messy bike shop. Which is what it is. Greeted by a beardy man you wander through into an area which looks like a kitchen - complete with sink and dining room table at which someone, another beardyman, sits lacing a wheel. I didn't visit the upstairs, but I'll wager they look like bedrooms whcih someone has filled with cycle clothing. It wouldn't have surprised me to find a member of staff having a kip.
The back garden has bikes lined up on the lawn - new bikes mind, for sale. Andthe sheds and outhouses contain more bikes, many hanging from meat-hooks from the ceiling. Nice bikes though.
F*** Evans, this is what a real bike shop should look like.
(From the Spa Cycles? thread, 2011)
Yes and no. Firstly, titanium is not stronger than steel, only half as strong. Also half the weight in steel. But that's not the real issue here.why would you go stronger but heavier - surely if the material is stronger you use less of it
This vibration issue is one raised relatively often. Engineers are very concerned with vibration since it is a very destructive force. They measure it and understand how to work around it. I have not yet seen anyone do a vibration analysis on similar frames built from different materials but I bet the minute I hit enter someone will find one on google.Here's a thought; the way a material absorbs or transmits vibration will also have an impact on how rough or smooth a ride is perceived. Different materials will transmit or absorb shock and vibration differently even if as asserted that a double diamond frame doesn't flex in the vertical plane (and that assumes that the vibration is always applied in the vertical plane).
The other area I think affects ride feel is the interaction between frame and fork - the materials used, the contact area, the solidity if the contact, the angles involved, the compliance of the system and how vibration is propagated from through frame.
I'm not convinced that (carbon apart) that different metals for frames do not feel different ...
Anyway, until that happens I'll give you a little thought experiment on the vibration issue.
You have ffive tubes of equal dimension and equal mass. Say 30mm dia and 900mm long.
Tube one is a steel pipe.
Tube two is a carbon pipe
Tube three is an alu pipe
Tube four is a wooden pipe
Tube fie is a titanium pipe
You have some sort of vibration machine handy - something that really creates a buzz of sorts. You place the tube's one end on the machine and you place your chin on the free end. You switch the machine on and feel the vibration in your jaw.
Do you really think you will feel any sort of difference amongst the various materials? If you say yes, you have to explain where the compliance takes place in the system.
If they had different wall thicknesses maybe?With different densities, how can they have both equal dimension and equal mass?
