- Inside my skull
How do you stop the stuff falling out as you pack the other half of the tyre?
Lay wheel down flat
So all of it falls out?Lay wheel down flat
I think that bananas might be a better bet. They follow the curve of the tyre and you don't have to worry about them turning into mush in your pocket.You partially mount the tyre then push the grass in and firm it down with a Park Tool Grass Tamper. It's a bit pricey, but best to use the right tools for the job.
Do you finish off with a strimmer to neaten up the stray bits?Lay the bike down run a tyre lever around one wheel rim and stuff the grass in pressing the tyre back on the rim as you go. Use a tyre with spoke hook to stop tyre popping off as you go round. You can even leave the wheel on the bike.
Thinking about it if you had enough bananas they could be used to stuff your tyres.
Actually, @GuyBoden did upthread:4 pages and has no-one suggested using an inner tube
I find it much easier to bring a few spare innertubes on every ride.
Or old padded shorts, finally an environmentally friendly way to deal with cycling clothes that have reached end of life.Ha ha, missed that. Can I suggest old socks ?
